Canola seed are white after frost
  • ckd129
    • May 2000
    • 29
    Just wondering if someone can anything new to my situation. The canola I harvested has a large percentage of white shriveled seeds. Some of the neighbours have nicer looking (black) canola, although small seeds. Some of these crops were greener when the frost hit.
    Is there any explanation beyond the stage of my crop and temp it got too. I can't explain why the field across the road wasn't hit as hard, even though it was later. Differences in canopy cover?
  • gwynplaine
    • Jun 2004
    • 70
    Where are you at? What kinds of temps did you see? Most importantly, what kind of disease pressure (specifically Sclerotinia) were you seeing? I'd be less inclined to suggest frost, in your case, as I would to suggest Disease. Especially seeing as the later ('greener'?) crop was not as affected. I've seen, here, the earlier, denser crops more affected with Sclerotinia than the later ones. Disease is a timing thing.
    • cris
      • Feb 2000
      • 143
      Much of the frozen canola is white/grey and shrivelled. Most is comming out as dockage. Canola I sprayed with ronalin still has the white shrivelled seeds in it but no sclerotia in the sample. The unsprayed has a small percentage of sclerotia in the top screen when doing dockage. The sclerotia is black, often an oval shape sometimes mistaken for canola (looks like mouse crap)
      • r.reid
        • Jan 2004
        • 150
        Sorry to hear about your crop. Your not the only one with it. We noticed that the frost hurt varieties differently. We had one field that had invigor 2733 and highlite 289. The invigor beat it hands down. It had less white seed, and bigger blacker seed to. I'm hearing the same from some friends of mine. Sounds like RR canola got hit bad.
