CNH DEF delete
  • Taiga
    • 1493
    CNH DEF delete
    Have a 2019 6.7L FPT engine that I started for the first time since winter and went to fill the DEF tank, level was sitting at 23%.
    DEF started draining out onto the ground, so the tank is cracked probably.
    I would rather just eliminate the DEF system than fix, the DEF tank was already replaced once two years ago.
    Who can fix this, can PM me if you want.
