You mention you have your lights set at 3 inches, I don't know very many people who run below 6, that will make your lights jump around alot.
GPS systems
Seedsman, don't get me wrong, I agree that going to the complete steering is the way to go. The two favorites I have are the Accutrak and the EZ-Steer.
I only use the EZ-Steer in my pickup for pulling a Valmar and then I have Accutrak in my Tractor, Sprayer, Swather, and Combines.
The complete basic Trimble system running on the free WAAS signal is about $8-8500. This unit can be moved from one tractor to another, or to combine, swather, etc in about 15 minutes. If you want more accuracy, then you can pay up to something like 40 grand for or - 1 inch (only used for mounted implements).
The basic Accutrak unit last fall was quoted to me at $6500 plus reciever, and about $5000 for each additional unit (tractor, combine, etc).
For a complete listing of all 29 companies in the GPS guidance system market, check out http://www.onlyguidance.com/index.html
How complicated is it to run any of the above systems if you had a field like the one I have that is 700 seede acres in one block but has about 37 sloughs,tree bluffs and rock piles on it? Also has some pretty good sized hills olong one end of it. I get lost combining this field in the middle of the night-loose all my sense of direction.
