electrical problem
  • gstolz
    • 1
    electrical problem
    Has anyone had a problem with all electrical power lost from the control panel in a 2188 case combine?
    • 17489
    Sorry I can't help you. Not my brand of combine but it would have been nice if some one who has them would have responded. Obviously, eliminate the easy causes first. Power sources....fuses, mice chewing wiring etc. Does it even power up? The newer the combines the more electronic shit on them....multiple modules etc....problems.can be like chasing ghosts.
      • 3956
      Ya bummer no one had an idea.
      Probably found problem or fixed real good with the big hammer by now.
      Don't own one either.
      Is whole console dead or do analog gauges and grain monitor still power up/respond? If so there is some power in the area.
      Those modules are doomed to wear out. Key pads quit or the wiring from keypad to module breaks up and creates a phantom issue that comes and goes. If whole console quit, poor grounds, broken wires or burnt relays are good to check.
