John Deere 8450 or Versatile 835
  • chaser
    • 45
    Looking for older reliable tractor was wondering what is a better tractor the John Deere 8450 or the Versatile 835 good points and bad thanks
  • food4u
    • Oct 2003
    • 577
    Neighbour had an 8450 and a 555, and he
    cussed the JD because of shorter wheel
    base making it very rough riding.
    • BTO_farmall
      • Feb 2012
      • 509
      EASY... Go with The Versie, cept go with an 846, Little Newer, Little Nicer, Little More Horsies, And can be Had 4 Not Much More...........
      • wauchope
        • Mar 2003
        • 51
        I have a ver 800 in very good mechanical shape , $5000
        • ProFarmer
          • Mar 2005
          • 477
          versatile 846 most trans parts already obsolite... stay with jd
          • frustrated1
            • Oct 2003
            • 326
            Beg to differ… all parts are available… just redid
            ours… Versatile's own transmission so no jobber parts
            but essentially the same tranny in everything from 800
            thru 976… I bought some gears from wreckers due to
            price but everything was available new. IMO.. old
            versatile way more reliable than old JD
              • 9412
              Very simple! Unitized constuction vs componentized construction.
              Roll the front axle away and pull the engine to do clutch or drop pan. Pull the rad to do hydraulic pump. High speed engine shaft, the list is ENDLESS. Labor on the Deere will kill you.
              855 cummins bullet proof. Easy component R&R. Atom jet hydraulics available. You couldn't give me a 50 series or older Deere!!!!!!!!!!
              • Hopperbin
                • Dec 2007
                • 6562
                True labour at 100dollars per hours these day go with the versatile 835 846 or bigger or newer etc. Cannot immagine 846 being obsolete when I just did an 835 not that long ago. No problem with parts then. Most likely same transmission.
