Miller wildcat 200 portable welders
  • ALLFARMER
    • Sep 2002
    • 1640
    Just ordered a new Miller welder. 6500 watt generator, 14hp Subaru gas motor, 50 - 200 amp range 12 hour run time.
    Needed to run a air compressor to keep my dozer clean...rad and minifolds. Also welding and grinding on my v cutter. Have 10 days of welding drill stem yet this spring/summer.
    Does anyone have experience with these Miller wildcat 200's Thanks
  • cropduster
    • Feb 2001
    • 666
    Will melt more rods than YOU want to carry!
    Have OLD AE200.Will still DO THE JOB whatever it might be!!!! Just use common sense on the service!Protection from the elements would be nice.I`ve even graduated to reels for cables.Makes it unbeatably easy for those quick little touch ups!!
    • ALLFARMER
      • Sep 2002
      • 1640
      Thanks
      I called and ordered the cover for also. Spend that kind of money better buy the hundred and some buck cover for it. Especially if it's going to be out in the field waiting to be used.
