Grain Air Tubes?
  • gustgd
    • Oct 2004
    • 1009
    Grain Air Tubes?
    www.grainairtubes.ca
    Has anyone got any experience with these?
    Just saw them at the FPS and thought I would ask you folks?
    something about drying air by convection and that they are popular in northwest SK.
    Seems to good to be true, but you never know????
  • rook
    • Dec 2003
    • 313
    I like the idea and it should work for narrower bins. Don't know if I'd use it in a flat bottom though as it's just another thing in the way.
    I have a friend who mentioned in passing that he has a few and they work well.
    • Hopperbin
      • Dec 2007
      • 6562
      They are pretty pricy and I used weeping tile in my bin rings this last year because I seen that display at the FPS the year before. One day when checking the pile on top there was really warm air blowing out the top of the tube I believe taking moisture out and not putting it in the top of and down the center of the pile. The first one I used 3 times more weeping tile than needed because I had a hard time manually holding it in the center, I had it feeding in through a holder on top of grain auger. Next one I wired and staked to ground first and worked much better. I think I should use them in the bins also, something simple could attatch them to bin floor, I vacume but if you need to bin sweep it could be easily disconnected.
      • countryguy
        • Nov 1999
        • 685
        Hell of an idea Hopper!
          • 22551
          hopper thanks for the idea on that. I love when farmers think outside the norm and do their own thing - the best ideas in ag come from these guys - always.
          • rook
            • Dec 2003
            • 313
            The weeping tile is a great idea. If using it with a bin, what are some set up ideas for the top of the bin? The real grain tubes have a dispersing cap that is chained to the top. With weeping tile, do you think one could just attach the weeping tile to the side of the bin-top opening and fill with the auger beside it? Personally I can't see any problem with that and it would save a bunch of hassle with trying to center it and having a dispersal cap...
