Bourgault 8800 with knives on 8 inch spacing
  • caseman
    • Feb 2003
    • 197
    I used 2 inch spoons on my airseeder last year and now I am
    thinking of switching to a hoe opener or knives.
    The soil flows better around the hoe opener so I think that
    will be better than the spoons that seem to throw more soil.
    Anyone have any comments on the hoe openers offered by Bourgault?
    The knife sounds like a good idea but I wonder how much
    actual N I can put with the seed single shooting dry fertilizer?
    For canola and flax I will deep band ,some done last fall and the rest
    in the spring. It is the barley and durum that I would like to do in one pass
    with about 50-60 lbs. actual N.
    With the spoons I could probably get away with 50-60 lbs of N.
    but what would a safe amount be with ample moisture conditions
    using knives on the 8800.
    Waiting for your answer Shamus.
    Thanks in advance for all replies.
  • nw9flynn
    • Oct 2004
    • 137
    You are a braver farmer than me. I think you should look at the product "Agrotain". It is from philom bios and you treat you fertilizer and it allows you to increase you seed placed N.
    • countryguy
      • Nov 1999
      • 685
      Caseman,have you ever thought about sidebanding your fertilizer?If you're thinking about knives already,why not get some sidebanding knives so you can sleep a little easier at night?
      • caseman
        • Feb 2003
        • 197
        My 32 foot 8800 is set up for single shoot right know with a 225 bu. tank.
        What would be the approx. cost to set it up as a double shoot system?
        What double shoot knife would I use?
        Midrow banders would be the answer but that would be a big expense
        since the 8800 has to be modified to add mrb's.
        I think I will have to band some nitrogen ahead of seeding with the knives
        for my flax and canola. I will use spoons to seed my cereals so I can have a wider spread for nitrogen, about 125 lbs of 34-17.
        • r.reid
          • Jan 2004
          • 150
          What about dribling liquid N beside the seed row. Only costs about $30/shank for the distrubution kit. It's effective both in the field and on the wallet. We're switching our air-drill over to this as soon as the snow melts.
          • countryguy
            • Nov 1999
            • 685
            Caseman,you could probably buy a dual shoot kit for a 3225 for a song.Check out harvest technologies for the sidebanders.
            R Reid,are you going with a pressurized liquid kit? If so you can build your own for next to nothing.
            • grrrr
              • Jan 2004
              • 431
              I have used an 8800 for years. Started out with 2" spoons. Then went to hoe openers. Didn't notice much difference in soil disturbance. Just bought a set of used 1" knives with cabide tips. All the while I have applied N in a separate pass in October and will continue to do so because I can't possibly haul all that product in spring during seeding by myself. I also like a little soil disturbance in fall in heavy straw to help the soil warm up in spring. For me, two pass seeding is here to stay.
