Rotary Harrow for seeding
  • FarmForProfit
    • 75
    Its looking pretty grim so far. I
    remember reading a few years ago about a
    guy renting a rotary harrow set up with
    a valmar for seeding triticale. It
    might be to aggressive (deep) for canola
    but would it work for cereals? Unseeded
    coverage is $25/ac for unworked land and
    if I can get seed on it the coverage is
    250-300 depending on crop. Plus the
    crop will grow some moisture out.
    Hopefully the sun comes out and the wind
    blows until the middle of June and I can
    drill everything but I'm looking for
    plan B.
  • wd9
    • Nov 2000
    • 3196
    You can adjsut the angle of cut on the phoenix from real aggressive to almost rolling along. No reason if the ground is real wet, probably why you are contemplating this method, why it wouldn't work for any crop. I have a valmar on heavy harrows, same thing with setting, really angled flat and they disturb very little ground. Would work well IMHO.
    • Dwh039
      • Apr 2011
      • 2
      I put an air kit on a phillips rotary harrow and
      have a tow between air cart to apply the seed
      and dry fert. Works well with canola and have
      seeded wheat, oats and barley with it as well.
      • riders2010
        • Aug 2010
        • 2205
        if you don't mind me asking what type of hoses and set up did you use for distribution and was it set up like valmare with a deflector to spread etc. Thinking that may be the only way to do it with a heavy harrow system.
