Roundup solution in tank
  • rook
    • Dec 2003
    • 313
    We get mostly custom spraying done so I don't have much experience with spraying. I have a half a tank of Roundup solution left in my little yard sprayer that has been sitting there for a few weeks. The spray mix used to be blue but now it is clear. Is it still any good? Thanks for any tips.
  • dfarms11
    • 539
    no problem, roundup will last all year in solution. go giver.
    • ado089
      • Aug 2004
      • 1754
      Not if it's in a plastic tank exposed to the sun. Sunlight will break down glyphosate. Also if its slough water the organics in it will neutralize glyphosate as well. Clean water in the shed it will be fine.
      • dfarms11
        • 539
        yes you are right, it will break down, but not to the point of useless. It will still work. I'm thinking garden sprayer, probably higher spray rates as not computer controlled, will turn out just fine.
