3.7B$ to lease 4400 oil cars for how long? AND... How is this not an export subsidy?
    1)How does throwing $3.7B not end in USA countervail export duties on AB oil?
    2)Would Quebec actually allow multiple oil trains through [to eastern Canada] after the oil train fire disaster wiped out a town... a few years ago?
    3)How does this not end up costing away more than 3,7B$???
    4) total benefit = $5.5B$?
    5) Why not let the oil Co's ship their oil... the best way they can, when it makes sense to them?
    6) does this put grain shipments in Western Canada at risk?
    The Math... At 3 locomotives per 110car train, 120 engines @ 3M$ per engine is $600M
    and,
    new oil cars are said to cost $120K-$150K/car...= $135K*4400 oil cars=$600M...
    $1.2B to buy 120 unit oil trains...
    why would WE lease the rail oilcars for $12K per month???
    Background: Interesting reading?!
    Widely reported that... CN bought 200 locomotives for $3M each that are being delivered as we speak... in 2017
    Pipeline News article:
    "Notley’s $350 million doesn’t come close to buying 7,000 rail cars and 80 locomotives
    Brian Zinchuk / Pipeline News
    DECEMBER 3, 2018 11:46 AM
    Altex Lashburn
    Expect to see a lot more of these.
    Photo By BRIAN ZINCHUK
    On Nov. 28, Alberta Premier Rachel Notley announced her province is going to be acquiring unit trains to get her province’s landlocked oil moving. Not only has she committed money to Trans Mountain Expansion, but now rail, too. This premier is serious.
    However, there’s a big problem with her numbers. She spoke of $350 million to purchase up to 7,000 rail cars and 80 locomotives. That $350 million doesn’t come even close. It might be enough to lease those units for a few years. Her stated intention was this was a short-term solution, and the life expectancy of a locomotive and tanker cars is easily into three or four decades.
    However, she said, “Alberta will buy rail cars ourselves in our fight to get top dollar for the resources that belong to every Albertan.”
    I never saw “lease” mentioned once.
    Notley spoke of 120,000 barrels per day (bpd) of capacity. Her initial statements weren’t very clear, as someone with little knowledge of the business might think she just meant two sets of 100 or 120 car trains. That wasn’t at all what she meant.
    She meant enough trains to keep 120,000 barrels per day in motion, each and every day. That’s a lot of rail cars, and a lot of locomotives.
    One of the few things I learned in my failed attempt at engineering college was how to do table napkin estimations. Your numbers may not be perfect, but reasonable estimations will usually see the errors cancel each other out.
    A unit train will typically be 60,000 or 70,000 barrels. So 120,000 seems to indicate two units of 60,000 barrels each. At 600 barrels per car, that would be 100 cars, but if we have 20 per cent diluent, then that’s 120 cars. (The diluent can also be as high as 30 per cent, but then again, some cars have a capacity closer to 720 barrels. You take 120 cars at 720 barrels each, then subtract 30 per cent diluent, and you get 60,480 barrels. Like I said, the errors tend to cancel each other out.)
    The older DOT-111 cars which barbecued a Quebec town are being phased out now for crude oil. Newer, safer DOT-117 cars are in. And the only price I’ve been able to find was a 2015 blog entry that said 117s, at that time, cost US$160,000. At today’s exchange, that would be $212,000 Canadian. However, I have also recently seen the number $135,000 tossed around, so let’s use that for the low end.
    If you’re putting it on rail, it’s going to be at least a seven-day haul. That seems like a reasonable, minimum number. When Notley initially referred to two unit trains, and 120,000 bpd capacity, everyone parroted that without any thought.
    One unit train with capacity of 60,000 barrels can not move all of that in one day from pickup to delivery, nor can two unit trains move 120,000 barrels in a day.
    A train is not like a plane, which can take off, span the continent, disgorge its contents, and fly back to its place of origin in the same day. To move 60,000 bpd (one unit train), you need one train at the loading point. You need a second at one day’s travel distance. You need another at spaced out along the line at another day’s travel, for as many days as it takes. So if you have a seven day travel, you need seven trains spaced along the route, going loaded. Then you have one day unloading, and another seven trains for the seven days coming back empty (but likely hauling diluent). That means at the very minimum, 16 complete unit trains are needed for each 60,000 bpd run.
    Notley’s numbers show 7,000 cars, enough for 58 sets of cars (unit trains) and 80 locomotives, enough, at two apiece, for 40 trains.
    There’s a problem with her numbers, however. The current standard locomotives used by Canadian railways cost US$3 million each as of December 2017, when CN bought 200 locomotives for US$600 million. That’s $3.859 million Canadian, each, at the exchange rate at that time. Notley spoke of 80 locomotives – that’s $308.7 million. That only leaves $41.3 million for 7,000 rail cars, or $5,897 each. That’s obviously way too low. So either there’s some leasing considerations involved here, perhaps on the locomotives, or the $350 million is way too low. Remember they were asking the feds for half? Even if the feds coughed up an additional $350 million, that still leaves only $55,900 per car.
    My math shows, on the low end, a price tag of $945 million for new rail cars alone. Coupled with ~$309 million for locomotives, and you come in at $1.254 billion. At the high end, it would be $1.484 billion for cars, totalling $1.793 billion including locomotives. Either way, it’s a heck of a lot more than the $350 million announced. Unless she’s leasing, Notley’s $350 million is only one-third to one-fifth of the money required to buy all these new trains, and no consideration has been given to staffing or operational costs.
    Even so, that is very small potatoes compared to the money Alberta is losing right now, each and every day.
    If we can’t build a pipeline, build those trains, whatever the cost.
    Brian Zinchuk is editor of Pipeline News. He can be reached at brian.zinchuk@sasktel.net.
    Editor's note: this is an updated version to reflect the pricing of locomotives initially in U.S., not Canadian, dollars."
    • 17506
    Why not just build a couple of pipelines. (Sarcasm)
      Can we imagine... 99 oil cars that had instead crashed in the Rocky mountains... and what a disaster that would have been...
      and,
      Altex Lashburn
        Nice Pics!
          • 17506
          St. Lazar Manitoba, CN derailment, TomBoy.
          Fits the narrative doesn't it?
          • blackjack
            • Feb 2004
            • 798
            Totally bizarre NDP’s supposedly our social conscience party are so desperate to get elected she (Notley)would sell her soul and our tax money to the company store(so to speak
            ).Environment saviours I think not.
              • 5470
              One oilfeild in Texas will have 6 new pipelines pumping 4.5 million bbl day by end of next year.
              Probably before TM starts up if Mr Trudeau is the ramrod on the project.
              US is down to 320K bbl day imports from 14 million/day back in the "peak oil" scare-mongering.
              https://www.bloomberg.com/news/articles/2018-11-21/opec-s-worst-nightmare-the-permian-is-about-to-pump-a-lot-more
              A bit dated but lots of good long term charts.
              Did climate change start to become a phobia about the time the peak oil scam played out completely?
                The cars can be a storage play as much as they can be for transport. 7000 cars is 5 million barrels that can sit on a siding for a few yrs until we get rid of the rot in this country. Its probably just a place to park some of the oil until some pipeline capacity comes on. They might deliver some of it by rail though. They don't want to have to shut in production when there is no need to do so.
                The enbridge line 3 crosses my land but they say they cant be in service for another yr because the US leg is held up so they are going to fill it up with oil and let it sit in the pipeline until then.
                I am not an advocate for oil by rail unless necessary but we have to do something to show we are fighting back. Protests wont shut down the rail lines.
                  • 17078
                  If buying railcars is a subsidy .....what is buying a pipeline considered?????
                  Bottom line .....neither has moved more oil .
                  • Rareearth
                    • Aug 2012
                    • 1619
                    Just a question.
                    Fort Mac, how do they get the oil to Edmonton? They have had many trucks hauling on the highway in the past.
