Hurricane Michael going to improve harvest weather.
  • poorboy
    • 907
    The last hurricane pushed into the middle of the US. That massive swirl of air needs a lot of air rushing in to fill the void of air in the eye of the hurricane. The jet stream has been pulling air out of the artic for the last month to replace the air from the last hurricane because it ran to the Center of the US. Has also been dumping rain into middle of the US that got pulled up from the south and west.
    Now the new hurricane Michael is projected to run from the Gulf of Mexico up the east coast. If Michael remains strong enough as it gets north it is going to need replacement air, which should switch the jet stream back to pulling air from the west coast across to the east coast to feed the hurricane.
    Air from the west coast should be WARM. Last hurricane took about 3 days for the major air change after the hurricane hit the middle of the US. So about 3 days after the hurricane hits the NE of the US should bring us a weather change.
    So, you read it here first. Better weather coming by the middle to end of next week if hurricane Michael can keep its strength as it runs up the coast.
    Makes sense..hope your right..
    • macdon02
      • Sep 2007
      • 1858
      There's also Sergio on the west coast and a Mexican monsoon at play. Both headed toward the great lakes. What I'm getting is relatively little precip till Dec 7 but frigging cold by month end. So if it isn't melted by then that's the last crack at it
        • 3958
        It's gonna take a lot of improving...Snow areas Oct 9(clouds to the south)
Name:	Snow Oct 9 18.jpg
        • redleaf
          • 391
          [ATTACH]3514[/ATTACH]
          Interesting picture 101. Where did you find that ?
            Ground is getting cold next snow will not go.
            Last night was brutal cold
            Fat lady is standing up
              • 10009
              Clearing her throat, walking to the mike.....
              How about that satellite pic without clouds...No snow here but all around us...just can't be rid of those evil clouds, evil effects like the SMOKE, volcanoes. Oh but it's too F*ing HOT, Climate Change Nazis and their propaganda!
                I don’t like the weather pattern
                  • 22653
                  Very 1 st time in 5 weeks this finally shows a pattern shift 5 days from now ...
                  Up till now it has showed cold and wet with no movement in jet stream .
                  Shitty thing is we are still under snow with more rain or snow Friday before the change happens . Days are getting short and time is running out on everyone.
                    Betcha we get 2-3 weeks of abotiginal summer with way hotter than normal temps
                    Oh and that will make the news
