Dont Call It Global Warming
    Tweety its too bad you couldn't have sat in with me while I studied systems dynamics. If you had, you would realize that chaotic systems like planet earth cannot possibly stay in equilibrium all the time. You are looking for constistancy in a system that has millions of externalities, CO2 being an insignificant component. Every thing you think you see is all in the normal realm of variation and volitility in such a system. These systems change and rebalance all the time. They do not tip over into catastrophe without some hard external input.
    The other thing you would have found out is that chaotic systems cannot be accurately modelled. The temp variation you think will be happening is well within the modelling error.
    There is no climate emergency other than what mother earth has been dealing humans for the past 2 million years.
      And to deal with volatility, you integrate. Area under the curve. Did you fall asleep in class for ALL the rest?
      You just can't remain on the subject. What is Climate. What is weather.
      This is absolutely pointless
        Jazz or A5. Name one major scientific organization that says increasing CO2 levels are not causing the greenhouse effect and global warming.
          Yeah unfortunately solving for the entire earth is a little more complicated than that. How many variables affect the earths climate? How many do we have accurate measurements for? Have you measured the CO2 being liberated from tectonic plates?
          Flawed incomplete data, estimates being fed into chaotic system models yields wild errors and the error bars grow rapidly as time is added to the equations so the results further out are practically garbage. In many cases they leave the variables right out of the model otherwise it would be cranking away forever and never converge.
          Any other fields you know of trying to do 100 year projections of chaotic systems with hundreds of variables they cant even measure? This is junk science at its worst.
            Woe! Slow down. You just can't get past the religious notion you are either a believer in global warming and crazy or you're a denier and crazy. Catholic and Protestant.
            The data with record lows in Antarctica hints its CLIMATE may be cooling, won't know for 30 more years
            the record highs in Arctic shows its CLIMATE may be warming, won't know for sure for 30 years.
            Again, not so hard to understand. They are just temperature readings - you know - a thermometer - they been around for a lot of years, water boils at 100 c. and freezes at zero. Easy to calibrate.
            Leave the meaningless emotional socio-politcal BS out of this discussion. Is that possible?
            AF5, We know a few things. Temps have warmed a couple degrees last hundred years which means the CLIMATE for the planet is warming. A relatively steady CO2 has been around a long time, the last 100 years have shown it to go from 300 to 412 ppm. We know since the 1800's that several gasses trap heat. It's why earth is warm and the moon is cold even though they are the same distance from the sun.
            Yes or no?
            Can I get a citation for the couple of degrees of warming over the past century ? None of the credible organizations are making that claim that I have seen. Can't respond to the entire paragraph until that falsehood is rectified for proven correct.
              Any other fields you know of trying to do 100 year projections of chaotic systems with hundreds if variables they cant even measure? This is junk science at its worst.
              If only they had a way to describe the chaotic CHANGES had over a period of time - for say oh pick a number - how about 30 years. Wonder what they could call it, I would suggest they use CLIMATE. What would make it even better is if they had a complicated instrument yet to be invented or discovered that could take a temperature. Wouldn't that be great. And even maybe someday someone could figure out the math behind taking those chaotic temperature readings and somehow come up with a number that represents them all equally weighted. Then year after year you could figure out if that chaotic system is rising or falling. Maybe one day. Hopefully.
              Wouldn't that be wonderful. Then this stupid discussion would be over.
                  Seems someone has invented a temperature taking kind of device.
                  AF5 - who cares if its 1.5 or 2.0 or 1.1 or a couple.Not important for this discussion.
                  <iframe height='100' src='https://www.theworldcounts.com/embed/challenges/21?background_color=white&color=black&font_family= %22Helvetica+Neue%22%2C+Arial%2C+sans-serif&font_size=14' style='border: none' width='300'></iframe>
                  Darn, doesn't work. Here is the site. https://www.theworldcounts.com/challenges/climate-change/global-warming/average-global-temperature https://www.theworldcounts.com/challenges/climate-change/global-warming/average-global-temperature
                  So is CLIMATE right now going up or down?
                    Sure would. It would be also nice if such a model took into account the hundreds of other variables that affect climate, actually accounted for past data accurately, admitted inherent uncertainty in the results and left the politics and policy out of it.
                    Wouldn't it be nice if such a model actually made an accurate prediction, then we would have the basis for a theory to work from wouldn't we? Then we would have some way to test all that conjecture like arctic ice free, end of skiing, no snow, more wildfires, crop failures, statue of liberty under water (a personal favorite of mine), ME uninhabitable, cold equals hot, etc.
                      You guys going to answer this or just ignore it again and again! LOL
                      I have asked many times over many months and no one has any example. Just crickets!
                        Read about their data..."To better illustrate what’s going on with the social and environmental challenges that we cover on this site, we have chosen to represent the data using ‘real time’ counters – in the hope that the reader will get a better feel for what is going on right now, and around the clock. These counters are based on various point estimates and projections, and may therefore not represent scientifically accurate numbers."
                        On sources..."We use the upper estimate based on current climate policies. These policies are projected to cause global warming of 3.1-3.7°C by 2100 compared to pre-industrial levels (14 degrees C)."
                        Just selective data, why not lower estimates or the range of each? Mainly because within margin of error!
                        Totally a guess, worth ZERO. Doomsayers for 2 degrees, but those are invented.
                          So being wrong by a factor of two isn't important ? Sacrificing our modern way of life and our economy and industry , And spending trillions based on Data with a 100% error bar is wise?
                          I have no idea how to answer your last question about climate going up or down ? That makes as much sense as the press release from COP25 where they claim that world temperature will double. Double in absolute degrees Kalvin?Think about that statement before you get too deeply in bed with this crowd.
                            I already showed you the flawed NOAA and NASA data.
                            What these orgs say to MSM is another story entirely and meant to keep their socialist funding going.
                            Tony Heller dug deeper on this Antarctic record temp MSM garbage. This was on an island station 2000 miles from the pole and the observatory sits on the eastern downslope from a mountain range. They got a chinook and called it global warming.
                            Just for reference, 2000 miles from the north pole would put you on the same latitude as Yellowknife NWT which easily gets above 18 degrees in the summer.
                            What garbage.
                              No body on earth will ever be "peer reviewed climate scientist" credible/honest/smart/unfunded enough for the CULT!
                              Many of us have said YOU can't prove those DOOMSDAY predictions, we don't need to disprove first! Countless examples of FAILED predictions by YOUR scientists doesn't make you wonder? Truly a CULT!
                                This site contains all the temperature data for hundreds of canadian cities for the past 20 years. I challenge anyone to identify a warming trend in that data set.
                                https://yourenvironment.ca YOURENVIRONMENT
                                But if you dont want to do that, you can see how the first round of predictions went when Canada first jumped on the crazy climate bandwagon back in 2001.
