Integrity Post Frame Buildings
Commodity Marketing
Tools
Jan 20, 2020 | 16:56 1 Curious what people’s experiences have been with integrity post frames? Have you been happy with the finished product?
Has anyone used the concrete columns in the ground as opposed to the regular treated wood?
They are pricier then some other post-frames companies once you add a few of the options, but would be curious to hear if others think the value is there for the extra dollars. Reply With Quote
LEP
Jan 20, 2020 | 17:35 2 My brother has an Integrity Post Building with cement piers or bottom. Its a good building. He likes it. Reply With Quote
Jan 20, 2020 | 21:42 3 If you go with them, make sure you get a good crew. We put an Integrity concrete post building up, and while the building has been good, the crew was terrible. My dad basically had to babysit them, and when he wasn't there, they made some serious mistakes.
Jan 20, 2020 | 23:14 4 I have three post frame buildings, one is an Integrity. Non concrete posts though, these are all just cold storage, keep machines out of the sun and weather. All the buildings look the same, the last one was done by UFA and was the cheapest per sqft. I would shop around and get multiple quotes. Reply With Quote
AllisWD45's Avatar Jan 21, 2020 | 06:23 5 Strayt "A" from Balcarres Sask. Excellent people top notch crews. They built two for us over the years the first one is 20 years old and as good as the day it was built. Reply With Quote
Jan 21, 2020 | 07:50 6 We had an Integrity shed built in 2010 with the concrete posts. Cold storage. Not a single issue with the building-other than a few leaks where a screw missed the strapping. I think the crew did a good job but like bin builders, I had to pick up a lot of screws and nails off the ground.
The main reason I went with Integrity was the concrete posts. They haven’t heaved, or moved or anything.
Only put a bifold door in one end, and sliding doors in the other end-that was a mistake. Bi folds in both ends is the way to go. Reply With Quote
Jan 21, 2020 | 08:32 7 Like zee said it all depends on the crew
First one a carpenter built , its about 82 x 90 with lean toos, we helped , dad had to go to lumberyard every day for something he forgot
Took all summer
Next one was mcmunn and yates , crew was outstanding done in 3 days
Then next summer we added another 40 ft on , realized it (48x80) was to small , mcmunn again , crew were idiots , one was spinning powerturns in the field with a one ton , finally told them to **** off and another crew came and finished , job was good
Next one was a finished shop with goodon , crew and price were excellent , 4 days and done and finished to a tee with a big bifold and an overhead
The carpenter one has moved very little the other ones are as straight as the day they were built
I would sure recommend goodon, though, whole thing was a pleasant experience Reply With Quote
Jan 21, 2020 | 10:49 8 Experience with Goodon and Integrity, both good crews, no mess left behind, all sheds spray-foamed with bi-folds both ends. Hurricane force winds in about 2014 damaged pretty well all buildings on the farm, even moved a garage off the foundation, but never damaged a thing on the shed. We believe that the spray foam made the shed almost invincible. Reply With Quote
