Keep your fire extinguishers handy, harvest is coming
    Well, for the second day in a row we helped a neighbor and the fire department fight fire on a hayfield.
    Keep the water truck full and the tractor hooked to the disc. It's almost harvest.
    We are mounting a pump and firehose on our water tanker and mounting a homebuilt firefighting setup on the cart.
    Unless we get alot more rain it is going to be dangerous.
    Good idea thanks for the heads up....last year the guy that cuts hay for me was starting fires in what looked like to be grass green hay....the discbine was starting them regularly ...then a lightning strike to boot started something in an abandoned yard...days watching it.
      I heard recently that Fire departments are using and recommending leaf blowers to put fires out.
        It sounds like discbines on rocky fields can be fire hazards.
          Great ideas, everyone should keep this in mind.
            I heard the same thing. Would of thought it would have the opposite effect.
              We have laws and a harvest code of conduct.
              Every harvestor must have a water fire extinguisher and foam extinghuiser mounted on combine. usually somewere near steps.
              A fire fighting unit of 1000 lt must be in paddock at all times either on a trailer or back of a ute/pick up.
              Fire extinguisher mounted on augers.
              A shovel mounted on harvestors as well.
              Harvesting should cease when wind speed exceeds the centre figures hope you can get you head around it.
              Insurance companies go by it now, not law but may as well be
                Try this one full attachment
                  basically in my spot its "one out all out policy"
                  a few phone call radio chat on days of extyreme weather, you harvesting today nope then another says nope then nobody does or on windy days call my come over radio when you pulling the pin might say already then others will followe
                    We have an old 4 wheel drive and a 12' Rome disk that follows the combines around. We have had to use it twice in the past few years. Once in a neighbours field and once in ours. Without it things would have been far uglier.
                      When harvesting lentils there has to be a "manned" fire unit in paddock at all times whilst harvest is happening of lentils.....err that should be "manned or womanned" i guess.
                      Other guys have mounted self activating foam extingiushers in engine bays once a certain temp is reached they go off and fill engine area with foam never heard of any going off accidently
                        It’s “peopled” Mallee. #welcometo2018
