Water pump?
    Water pump?
    Other than the dealers 600 dollar water pump for my 4230 tractor, suggestions on where to find a new pump?
    Try your local A and I aftermarket dealer. $198
    https://allpartsstore.com/ItemDetl.htm?B2BSessionID=180718225615743&Category Seq=B&SelcBrand=JD&SelcMachn=TRACTOR&SelcModel=423 0&SelcSectn=C&SelcSubsc=C118&SearchItem=1&TextSear ch=&ItemNumber=AR98549
    If the housing isn't damaged You can also just buy the shaft and seal and rebuild it yourself, from them or probably still get the components from Deere.
      I found some Canadian suppliers for that 200dollar mark. Thanks, checking out a and I now. Plan is to rebuild it, but John Deere no longer supplies the shaft they tell me. Thanks again.
