New Grain Bin Cleanout System - GSI FlexWave Demonstrated at FPS.
    From AGCO News at Farm Progress Show www.AGCOCorp.com
    Farmers and commercial grain operations will soon have a more efficient alternative to grain bin sweeps, brooms and shovels for bin cleanout with new FlexWave®
    technology being demonstrated by GSI (Grain Systems, Inc.) at the 2017 Farm Progress Show in Decatur, Illinois.
    Currently, standard grain bins are emptied through a combination of gravity and augers or bin sweep technology. However, with these methods, there’s always a remaining level of grain on the bin floor that needs to be swept out. It’s hard, time-consuming, dusty work that can also be dangerous if this chore is performed while an auger is still running.
    GSI’s new, patent-pending FlexWave technology can eliminate this labor-intensive and inefficient task. The system utilizes two large liners that alternately inflate and deflate, gently pushing the remaining grain into a centrally-located conveyor trough for removal, without the need to enter the bin.
    A control system automatically senses the amount of grain and shuts off when the process has been completed. “FlexWave technology results in 99 percent cleanout and eliminates the risk of entrapment from falling grain or auger entanglement since it is truly a zero-entry bin unload method,” said Greg Trame, GSI director of engineering.
    Trame said FlexWave is also more reliable than conventional methods, since there are no exposed mechanical components. Another advantage is that perforated bin floors are eliminated, increasing capacity.
    Strength and durability
    Each inflatable liner can unload more than 100 tons of grain using less than one psi of air pressure. The liners are constructed of durable, commercial-grade material designed to last over 30 years under normal conditions. In addition, they can easily be repaired in case of accidental puncture with a simple glue patch because of the system’s low-pressure operation, which is gentler on grain than traditional options, protecting grain quality and profits.
    Grain hopper tank application
    Traditional grain hopper tanks are emptied by gravity through a cone at the bottom. With FlexWave, a flat bottom storage tank can be used instead, which not only increases capacity but also eliminates the need to install legs since it can sit on the ground.
    “FlexWave technology is another unload option added to GSI’s complete product portfolio and can be used with any standard current unload system,” Trame added. “This technology is exclusive to GSI for grain storage and represents an exciting advancement that supports our commitment to continuous innovation.”
    Field trials are underway, he said, to ensure proper aeration is maintained to provide long-term, safe storage. The first FlexWave offering is planned for 2018.
    Agriville admin.
    Thanks for the video, interesting concept but would want to see the work the are doing in regards to this and aeration. Seems that airflow could be comprised.
      Interesting concept, hopefully their prototype units prove to work.
      Good to see inventions that can decrease undesirable, dusty, potentially dangerous jobs.
        Yes. I wondered about the full air floor as well. And ripping of the bag.and what they use to air it up. But looks very cool. And the big question, price difference over a sweep.
          I like the approach. Eliminates a dirty job. Not likely that expensive when you think about what it would take to install.
