700 Pro Gps swath control???
    Just wondering if anyone knows how to connect the #1 hydraulic to the work control on the 700 pro Gps
    If I turn coverage on it paints on the map all the time if hydraulics up or down on drill
    The implement is entered as air drill with the correct width and 0 offset
    Can't find where to link it with the hydraulics.
    Thanks in advance
    Is there a "sense" wire on your monitor that you splice into a wire or work switch that is live when the drill is down? And then a setting in the monitor that tells it it is wired to a workswitch?
    I only have experience with Raven stuff but we ran into that once.
      Can't you just put in a generic pressure switch activated by one shank $57 at farmtronics comes with mounting bracket.. Though all i know is trimble and raven.
        It worked last year with the #1 hydraulic switch
        This year it's not
        I am thinking its in the settings somewhere
        It's factory pro 700 that came with Case 500 STX
          Toolbox
          Impl
          Hitch type
          Ehr1
            Oh ya make sure the work switch is on.
              Thank you
              It's working good now
              I have to get more familiar with 700 pro
              We have mostly used JD Gps in the past
