Carney’s policies going forward
    • 12773
    You must have read the report chuck? What percent of Alberta's farmland is currently taken up by oil and gas facilities?
    More or less than the 1% this report claims when we reach the imaginary net zero?
    Keeping in mind that Alberta currently exports almost all of its energy. Net zero would be just meeting our own needs. So roughly 10 times less energy production.
    I couldn't find the stats. So I'll use our own farm you're in the heart of oil and gas country as a proxy. Currently half a percent of our farmland cannot be farmed due to the above ground facilities.
    If these were recent facilities, that value would be much lower would you well pads strategically located without access roads.
    Very rough math, it looks like under your net zero scenario, would require 20 times more land per unit of energy production. I expected as much much worse than that if we really were honest with the numbers.
    ​​​​​​​If you have more accurate values, please share. You have a lot more time on your hands this time of year than I do in the tractors.
      • 5471
      This is the best explanation of the problems and opportunities for the western Canadian economy I have ever seen. Mostly energy but also logistics that effect agriculture.
      Pamela Wallin and Heather Exner-Pirot. Both from Saskatchewan.
      45 minutes but time well spent. Starts a little slow but from the 15 minute mark it is great.
      Not for everyone
      Don't miss this one Chuck, you will like it.
      [url]https://www.youtube.com/watch?v=73ChT-wWOR8[/url]
        • 22660
        Just go with green nuclear energy for clean dependable 24/7 power in one of the coldest countries on earth for 6 months a year … Canada .
        throw a few windmills and solar panels in cities that they can pay for and maintain to keep the climate cult happy .
          • 5471
          That might work for some cities.
          Saskatoon bills power to their taxpayers.
          They used to have their own power plant but sold it to Sask Power in order to get more dependable grid supply.
          Maybe the don't know how much cheaper it would be if they went back to wind generators?
            • 13474
            Danny ignored the Alberta Utilities Commission report and went ahead with her closed for business policy on renewables! Its the Alberta way!
            Read it and give up A5!
            "Alberta's utilities regulator has released a report saying the province's booming renewables industry poses little threat to its agriculture or the environment.
            "Assuming all renewable development locates on [some of Alberta's best] land, the percentage of [such] agricultural land loss is estimated to be less than one per cent by 2041," says the Alberta Utilities Commission report, released Wednesday.
            The commission takes a similar view of concerns that solar and wind facilities could leave landowners and the public with big bills for reclamation at the end of their lives.
            "Compared to some other forms of industrial development, renewable power plant projects have well-understood and relatively contained reclamation risks," it says. "The risks associated with groundwater and off-site contamination are generally low."
            The report is the first of two the United Conservative government asked the commission to produce as part of its inquiry into the province's booming solar and wind power industry. The release of the report comes shortly after the government removed its six-month moratorium on approvals for new renewables generation.
            The current report deals with agricultural and environmental impacts, as well as funding for reclamation and effects on what the government has called "pristine viewscapes."
            It found that renewable power is much less of a threat to the province's farmland than other forms of energy development and urban spread.
            "From 2019 to 2021, the largest driver of agricultural land loss was expansion of pipelines and industrial sites," it says. "Other key drivers… include urban residential development, mines and wells, and roads."
            The report said the proliferation of wind and solar projects will likely be more concentrated in some parts of the province than others.
            The report notes that the vast majority of wind and solar sites are located on poorer land. It also points out that wind farms use about five per cent of their lease area, leaving the rest available for grazing or suitable crops.
            It calls for more research on combining agriculture and renewable energy.
            The commission concludes that current rules are adequate to ensure reclamation, although there could be more clarity around the point at which developers need to pony up reclamation surety.
            "Existing power plant reclamation requirements are sufficiently defined to ensure effective reclamation, but no timing trigger exists to initiate reclamation," it says.
            It notes there was wide disagreement about when that financial backstop should be required, in what form it should be provided and who should hold it.
            The commission said there's no consensus on what landscapes should be protected for their scenic value.
            "It is very difficult to define pristine viewscape in a manner that satisfies all stakeholders, and that doing so may not be desirable because the value of a viewscape is subjective," the report says. "There are circumstances where a view that contains existing development may be of greater value to Albertans than a pristine view."
            The commission suggests those concerns could be handled on a case-by-case basis during the application process.
            Martin Olszynski, a resource law professor at the University of Calgary, said the report dismantles the government's expressed concerns about the booming growth of renewable power in the province.
            "It's an evidence- and reason-based wrecking ball that smashes the government's talking points and policies with respect to renewables," he said.
            In February, as it lifted the moratorium on approvals, Premier Danielle Smith's government announced new restrictions on renewables development.
            It said it would rule out wind and solar on Alberta's best farmland. It would also impose a 35-kilometre buffer zone around protected areas and so-called "pristine viewscapes" — a move that some estimate would rule out development over about two-thirds of the province, especially in the south, where wind and sun are strongest.
            Others have estimated the restrictions would affect 42 wind and solar projects representing about $11 billion in investment.
            Affordability and Utilities Minister Nathan Neudorf was not immediately available for comment.
            Olszynski said the commission's approach makes sense. He said the commission seems to be saying most of the tools needed to regulate the industry already exist. Problems can be dealt with as they arise, he said.
            "We can be nuanced and thoughtful about it," he said. "If you impose blanket restrictions, as the government seems to want to do, then you can't be nuanced and thoughtful."
              • 12773
              I read it. Apparently you didn't. Nowhere does it answer my question of how much farm land is currently consumed by reliable energy production.
              Do You know the answer? How does it compare to the 1% to you are quoting for renewables?
                • 13474
                A5, why don't you read the AER report or ask them?
                Instead you waste everyone's time with denying the conclusions of the AER report?
                  • 12773
                  Does that snarky answer mean you don't know the answer to my question, or does it mean that you found the answer and it doesn't fit the agenda so you are avoiding it?
                    • 13474
                    A5 you are denying science and evidence from the Alberta Energy Regulator and just about any organization or institution that you don't agree with, but you are not very good at making a credible argument!
