Pounding posts question.
    Can work as part of a rotation freewheat. Might give you some different seeding/harvest window options. Seeding rye in Sept, grazing through fall then an earlier harvest means you wouldn't be touching it at normal seeding time. You might have time to double crop - millet or a tillage radish type mixture after the crop is off. Uses a lot of moisture which in your situation would be a good thing but would be a constraint in many areas. I really like that you can have something growing from the first possible day in spring to last possible day in fall(kinda like grass) thats good for the soil.
