Manufacturers that don’t fix engineering problems
  • glensts
    • 2
    I also have the M100 and don't have that problem at all. I leave the AC switch on at all times and adjust the heat accordingly, If I ever turn the AC switch off then its fogged.
    • mbratrud
      • Jun 2008
      • 1019
      Found out the heat is turned down on many of these out of factory. So if your having problems find the heater valve and turn up. Then it works to run both heat and AC. Still does not adress the poor AC Unit they put in these things that start leaking after about 40 hours.
