Morris Maxim 1 Air Drill
    • 22551
    We have targets in and were very close then they dropped their pants, we are just going to wait this b/s out.
    Just got home from S'toon - wow lightning and very heavy rain - drove through water by the Travelodge. Areas east of there are getting pounded right now.
    • bjolsen
      • Jun 2010
      • 2
      boarderbloke: Thanks for the reply. I have a C-shank drill and if it were right now today I would put on a Bourgault seed boot once I've solved my lift problem.The Morris boots you are using I've heard good reports on except when you are buying!!Half again more,give or take a little.The mechanical problem you mentioned I've had twice in the same spot. The second time I took it to town and had the welding shop cut out the old pivot point and put in a heavier wall pipe with the same I.D. so the same plastic bushings would fit and that was two seasons ago!
      • boarderbloke
        • Sep 2007
        • 1991
        ya, I was thinking the same thing, getting some heavy wall pipe and re build. Need to change a bearing or two so will likely tear things apart after harvest, as I'll have to do most of them. are you putting on a paired row or side band boot?
