What is Fair for Parts?
  • checking
    • 2395
    That's funny, tubs.
    Good thing those bolts didn't require nuts.
    • sawfly1
      • 947
      Claas header multi coupler
      1 /2 of of one of the connections
      Inside , 450$ . The other half of the
      Coupler that turned out to be the problem
      was a modest 250, then determined
      It Was a white plastic seal .in that 1/2.
      But there is a seal kit , great
      Only 175$.
      Talk about designed to extract
      The most $. Are you going to risk 175
      Installing a hard plastic seal at 175$
      I don't think so. I took 250 for the whole
      Thing.
      In the end I am in for 700$ for a hard
      Plastic seal.
      Now if I could only find a seal , I would have a
      Complete spare.
      At least i beat them on the 5000$ they
      Wanted for a blacked out cebis screen.
      A guy on the net , had a cure that used a led light strip.
      2 hours and and a led light strip ,60$ back in businesses.
      • Klause
        • 3644
        Only 175$.
        Thing.
        Plastic seal.
        Complete spare.
        I've repaired two dozen cebis units. The backlight transformer is $9 and 6 solder points.
        Wurth sells those white seals. They're common in Europe.
        Actually, Wurth makes all the harnesses, wiring, and circuit boards for claas...
        Shop.wurth.ca
          Shop.wurth.ca
          i have really missed your "technical assistance " !!!
          • sawfly1
            • 947
            Thanks for the info Klause
