Case 500 Stx 700 display questions
    We have a 2013 case 500 with 700 display
    Our gps and hydraulics keep getting codes and shutting down
    Some of the codes that come up in corner post
    Colour display offline
    EHR Fault
    Engine fault code
    On 700 display
    Nav ii not connected
    If we turn tractor on and off
    Unplug 700 display
    Take relays out that control display and put back in and switch with other relays that are cool
    Most times relays are warm
    This seems to help temporarily
    We can go for days with no trouble then we can be shut down for hours some days
    Redhead came our to take a look and we had just changed relays and it was working when they were here and they could not find problem
    We tried a different gps receiver from combine and it did not help
    Any suggestions
    It seems to act up more when we move away from our Gps line to fill seed or do headlands
    And when we come back to our gps line it starts with the codes
    We would have done 400+ more acres to date if we have not had these issues
    The relays and fuses are inside buddy seat
    It seams to help if we keep the buddy seat open to keep it cooler
    We also replace the thumb drive in 700 display and it did not help
      Newer vintage than ours...
      Does engine go to idle? Maybe armrest controller, however would not explain GPS problem
      There are passive terminals that can do weird things when failing. Sorry not really much help.
      I hear ya on the lost productivity
        Weird.engine fault would be def.
        EHR is that a remote failed.
          Sell it buy a Versy!
            Screw the electronics. Let the equipment manufacturers experiment on their own time.
              The electronic stuff is nice when it works but sure is stressfull when it's not.
              When it works periodically and it always works when service comes out to look at and stops when they are not here is hard to dignose
                I know this is a simple thing to say but check all the grounds, this maybe a corrosion issue .
                Its nice when it works but you lost 400 acres of seeding productivity. I dont understand the value/efficiency in this. 400 acres means in total hours that has to be about 12 hours of troubleshooting. What happens if it starts to rain and it gets late?
                  We cleaned battery posts and grounds did not help
                  The redhead tech line knows me on a first name basis already.
                  I have been talking with redhead service more than I talk with my wife lately.
                  Most likely is a simple problem but have to find it
                  Redhead service was out for a few hours a while back and could not find anything
                  We have had a local mechanic out a few times and he could not find anything except for changing the relays out which helps temporarily
                  It has been acting up since May 6th some days are bad then we won't have any trouble for 2-3 days then some days it might happen one time
                  Then some days it happens several times.
                    Clean the ground cable from the battery to the frame and also clean the ground on rh front of engine block.
                      Jag we just had some problems with our 4wd (of the same series) too.
                      Eventually the " SCR warning " came up. Check out page 4-19 in your manual. The controller needed to be replaced (located in the front right fender), apparently they quit working, ours was replaced with only 2 weeks left on warranty.
                      Could be crystals in the line from the controller to the injector(under engine hood).
                      DEF may have crystalized over winter in your DEF supply tank.
                      Was loosing power and the warning eventually came up in the corner post display.
                      We also had a EHR fault, was total it's likely the in cab lever the you use to move the hydraulics. Something they have to do as it will need programing. We just don't use that lever as there are 5 others.
                      Redhead made a visit here too, ouch!
                        Agree with checking all grounds, had a problem with combine in the past ,took awhile to find it .It was a bad ground in wiring harness mid-frame. Was always putting error codes up.
                          Thanks for all the replies
                          Redhead out again this morning hopefully they can find the problem
                          Scared to see the service bill on a long weekend
                            Jag, Did redhead get er figured out?
                              Replace the two terminators...was having similar issues and it cured it.
