GT Grain Dryer
Machinery & Equipment
Tools
GT Grain Dryer
Nov 10, 2009 | 20:31 1 I have a 370 on propane with a finer screen on the bottom cone than on the sides. All my canola is still out and if this weather were to ever give us a break I would need to dry canola with this dryer. Does anyone know of any accessory that can quickly convert the coarser screen to a finer one for small seed drying. Al ong time back I recall a company in Saskatchewan that used to sell a curtain that hung around the inside for small seed dryng bt I can't find any info on them anywhere. Reply With Quote
makar's Avatar Nov 11, 2009 | 01:53 2 a dealers service man once told me with these dryers spray paint the holes and you will get by. I know what you are talking about, there was a tarp for these, the people came to the awp where i worked one fall to sell them. That was 30 years ago, good luck finding one. Reply With Quote
Nov 11, 2009 | 08:14 3 Had a machine with the same problem. Painting only helped a bit. I weaved wire through metal door screen. Did the trick for me. Reply With Quote
Oct 16, 2017 | 22:58 4
Quote Originally Posted by may-be View Post
Did you use nylon or steel mesh? You think self tapping screws and washers will hold? Reply With Quote
Oct 17, 2017 | 06:43 5 Pop rivets. If you make the holes bigger in screen you ll have to fix that when you no longer need the screen. Reply With Quote
